Component for Truck
Dynasty
I just got a 2000 Chevy Silverado Ext Cab and will be installing my HU and comps soon. I already have the HU (Pionner 5800MP) and will bet getting 6.5 comps with amp soon.
Crutchfield says my stock speakers are 6.75"...there are a limited selection of comps for that size and I was wondering if 6.5's will fit with no speaker adapter needed. Or will I have to do some modifying.
I also need comps that will blow the stock system out of the water. I want a very noticable difference in SQ and loudness. My budget is $200. I will not be using a subwoofer, just the front stage. I listen to rock and rap.
Any input?
The best budget comps are probably the Phoenix Gold Rsd65cs, at $129:
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=17540
You'll need an amp for those, there are many to choose from for under $100 that will power those. Here's a Profile 2-channel amp for $79:
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=4873
You could get an amp with more power to allow for future upgrades, etc.
You'll also need to throw in an additional $30-$40 for a wiring kit. This brings the total to about $240-$250, a little over your budget I know. You can probably lower the price to under your $200 mark by shopping for second-hand stuff.
Hope this helps!
-- Kevin
Also, I think I'm going to go with the CDT CL60's http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=5207
They are cheaper, sound very good (based on reviews on these boards), and free shipping.
Okay, I've never heard them, so I don't know how they compare to the PG's. You said you won't be using a sub. So whichever comps you choose, they need to have good low end. The PG's have good mid bass, not sure about the lower bass.
Those CDT's have a higher RMS power specification, so you'll probably need a bigger amp than the one I listed.
Also, does woofersect.com still upgrade to the CL61's for free?
No idea.
EDIT** Will any the PG or CDT comps posted eariler sound significantly better than amp Pioneer REV's?
I've never listened to the Pioneer REV coaxials, so I can't say. But from what I've read around here, most people seem to think they would.
Also, something I neglected to mention, make sure you deaden your doors! Properly deadened doors will make any speaker sound much better!
Hope this helps!
-- Kevin
I still have not decided.
Here are the options I have in mind...
A) CDT CL-61A powered by Profile AP600 (100x2 rms) $165
B) Cadence CWM6-Kit powered by Cadence TXA3002 (150x2 RMS) $200
C) Pioneer REV (coaxial) powered by Profile AP400 (65x2 RMS) $130
D) PG Rsd65cs powered by Profile AP600 (100x2 RMS) $150
B) Pioneer REV (coaxial) powered by Profile AP400 (65x2 RMS) $130
This is what I've just narrowed my choices down to for my girlfriend's car. I'm about to throw a sub in there (on her amp from a previous install). She would be satisfied with even the stock fronts, but I want to at least slap some decent coaxials in there. I was actually thinking about trying the Revs on the head unit first, and then later getting a cheap Profile amp if necessary.
But then I got to considering the fact that I could get a decent component set (that would probably sound better... I guess?) for a little more. I'd hate to get the coaxials and change my mind later, but I know she would be satisfied with anything, so maybe I should just get the Rev's...
Any ideas about how the Rev's would sound compared to the CDTs?
Cadence TXA-3004 $129 shipped
Cadence CWM-6Kit for $85
Use your 4 gauge kit... $free!
Eventually:
eD SQ10-S4 $70
Build a 0.3-0.5cf sealed box $20-50
...box would be so small you could easily stash it under the rear seat or something.
Use channels 1 and 2 for the comps, bridge 3+4 for the sub.
Unless you are going to do a three-way system with 8" in the door, you are dreaming... you will probably be disappointed.
The basis of all decent car systems is a biamped subwoofer/satellite system... get at least a four channel amp and use the rear channels for a sub.
Dynasty
Dynasty
Cleveland, OH
Gary S
