component amp suggestions?
rtillaree
F***, Strong
i had posted this a few days ago, but i will try again with a more refined base...
i will have a set of Boston z6's up front in the next few days (currently have sl-80's) and currently have a set of Boston pro50's in the rear, the z's are 400 and the 50's are 200 both are 3 ohm if not mistaken, my current amp is faulty, its a 600.4, worked pretty decent, im basically wanting to run 200 to both sets, i will use this on a mostly daily basis and i want crisp clean power, under 1k would be great and under $850 would be preferred...
thanks
im going to checkout the above mentioned real quick...
You want a 4 channel that'll do 200x4 ??? Am I right?
basically, or up to 250 max x 4 at 3 or 4 ohms...i just wnated some suggestions on something crisp, clean and reliable...i was getting close to grabbing a PG Xenon 200.4, ive looked at the rf t8004 and the t15004, but im not sure if the 800 would be enough and i think the 1500 might be too much...
rtillaree
F***, Strong
rtillaree
Orlando
bri487
