Competition Question
DonKing
Mississippi... YEAH!!!
what do all of these competition catagories mean???
for example...
i kno what the numbers mean...the number of subs...but what about the rest???
Super Street 1-2 ???
Super Street 1-2 Nw???
Street A ???
Street B ???
Extreme ???
ANOTHER QUESTION...
why does a competitors SPL score vary sooo much from comps. to comps.???
is it the song??? or the different mics??? what is is???
vary from comp to comp b/c a dif. mix of things. just like people's 1/4 mile varies depending on the temp so can your car audio man. the super street i believe means anything larger than a 12" but i'm not sure. extreme trypically means your car's interior has been modified, seat taken out or stuff like that. i'm not totally sure but i believe that is it.
adam
Mainly it is different classifications of how many woofers you have, the size of the woofers, the amount of amps power and such, then what kind of modifications you have done to your car..such as a WALL..etc
These rules are for DB DRAG:
Street A – A maximum of 2 subwoofer amplifiers may be used. Total subwoofer amplification is limited to a maximum of 4 “non-bridged” output channels or 2 “bridged” output channels. (Please see the definitions section for more detail regarding bridging.)
o 1 to 2 woofers 12-inches in diameter or smaller
o OR a single woofer that is larger than 12 inches in diameter but no larger than 15-inches in diameter
· Street B – A maximum of 4 subwoofer amplifiers may be used. Total subwoofer amplification is limited to a maximum of 8 “non-bridged” output channels or 4 “bridged” output channels.
o 3 to 4 woofers 12-inches in diameter or smaller
o OR a pair of woofers that are larger than 12 inches in diameter but no larger than 15-inches in diameter
o OR a single woofer that is larger than 15-inches in diameter but no larger than 18-inches in diameter
Street Division:
· Amplifiers used for non-subwoofer applications will not be counted.
· Subwoofers may not contain more than 2 discrete voice coils per sub.
· Cargo vans and commercial vehicles are prohibited from competing in the Street Division.
· Sponsored vehicles are not permitted in the Street Division.
Super Street Division
· 1-2 Woofers – No Walls
· 1-2 Woofers
· 3-4 Woofers
· 5-8 Woofers
· 9+ Woofers
Extreme Division
· 1 Woofer
· 2 Woofers
· 3-4 Woofers
· 5-8 Woofers
· 9+ Woofers
The classes listed above are the recommended standard classes for dB Drag Racing. Typically, all of these classes will be offered at multi-point events. However, if there are fewer than 8 entries in a given class, or if the event is a single-point event, the show promoter may, at his discretion, combine one or more classes in order to fully populate the elimination brackets.
Hope I was helpful..if you need anymore help just let me know! //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Blake
DonKing
DonKing
Oviedo, FL
avistar23
Doxquzme
    Jun 20, 2026
Doxquzme
    Jun 20, 2026
