Comparable to slash series?
Your math is off a bit. It would have to produce 1000 wrms to be 50% underrated //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
hahahaha... no
750 is 50% more than 500.
So it is 50% of it's output underrated.
In other words it puts out 50% more than its rated. or... 50% underrated
not underrated 50%.. that is nonsense, you can't half way underrate something without knowing the correct rating.
500 x 1.5 = 750. Technically that is a 50% increase since 250 is 50% of 500, so that is one way to look at it.
1 - (500/750) = .33 or 33% and that is the other way to look at it.
How do we say tomato again?
Correct but since the original rating is 500 watts I calculated from there. rather than 750 because thats not a rating on the amp.
I couldv'e chosen my words better though. "the amp is underrated by almost 50%"
So no one knows of an amp that can put out more power than the JL with as little THD? for the same or less money?
Hmmm well i may not be a genious but i'm pretty sure that criteria defines them as the best. not to mention the other features the slash amps have. (regulated power supply, advanced bass control, and with the v2's better cooling to reduce compression.)
You truly are retarded.
Dont be mad dawg its just the internets.
HAHA i don't get mad...
But I am sure being wrong all the time probably does get old....
I guess you should know.//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Find one post of mine where I have been wrong. Just one. //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
You obviously cant comprehend simple English
Here is one.
And i'm the dense one
you got ONE right!
While there is definitely a lot of fail in this post it is true the Ia 20.1 would not be a good amp for you.
The kicker zx 1500 would be a much better fit for your application
#1 my comments came directly from the specs of the amps.
#2 how the hell do you figure that amp to be the best fit for my application?
If you truly were trying to win sq comps, you would not be worried about either msrp or thd below the thresh hold of human hearing.
You have no idea what i would be worried about reguardless of my goals. And the level of THD "below the human threshold of human hearing" you are referring to is a variable level. yes there is a noticeable difference in 1% of THD. but hey if i'm worried about winning SQ comps i'd be worried about more than the threshhold of human hearing, i'd be worried about what analyzers hear!
If you really wanted to learn there is more then enough quality information on the importance of install, speakers and processing. Amplifiers are probably the least important factor of an 'sq' system.
OK i'll give you one of those mmats amps with the thd levels at 3% and see how many SQ comps you win smart ***
http://cgi.ebay.com/JBL-BPX-1100.1-IN-CAR-AUDIO-AMPLIFIER%2FAMP-SUBWOOFER%2FSUB_W0QQitemZ330334858461QQcmdZViewItemQQimsxZ20090602?IMSfp=TL090602157006r24005
//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif Not necessarily cheaper but a good substitute.
again, HOW?!?!
IQ says otherwise genius
how bout a few?
Here is one.
you got ONE right!
again, HOW?!?!
how bout a few?
Explain to me how comparing thd on two amps is relevent when both are inaudible? What does MSRP have to do with anything? Who pays that? I also said that was NOT the amp for you. That amp takes intelligence to operate. I never said what would be best for you. But this is your thread and you did give your specifics and asked for opinions as to what fits your needs so you obviously do not have a fucking clue. Like anybody ever doubted anyways...
You cant hear 1% thd on a sub. To say otherwise is ignorant and quite stupid. You arent anyone special. //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
You do not want to compare iqs with me I promise you.
Again I //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif at your ignorance and stupidity.
But I do applaud and appreciate the amount of effort I am sure it took you to worry about someone on the internet for not being 'mad'
//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
Explain to me how comparing thd on a class d vs a class ab is relevent when both are inaudible? I also said that was NOT the amp for you. That amp takes intelligence to operate.
I have won sq comps with class d's so what now?
because I said anything about the amps being class D? you are doing it yet again! no i said that they have 3% THD. and i'm comparing them because they are audible differences. maybe YOU can't notice the difference. but that doesn't make the difference inaudible.
and I assure you I don't want to compare IQ's with you. I'm not up for cleaning your brains up after your tiny little head explodes.
You brought in 3% from some completely unrelated source which had nothing to do with the amp in question. You stated 1% was too high. You can not hear 1% on a sub. The sub itself puts out more than 1% thd. Maybe you are too high because it looks to me like you are so retarded you cant even keep this thread straight //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
I can tell your IQ is quite high after you have brought so many well thought out articulate responses to the discussion. //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif//content.invisioncic.com/y282845/emoticons/hilarious.gif.02a037aad04aa96f19982b298a3d70a8.gif//content.invisioncic.com/y282845/emoticons/rotflol.gif.b453361716769b8110ddefc85ff03cd2.gif
cotjones
cotjones
Wilmington, NC
E-RPM SOFT COM
