So is a comp like a small subwoofer? could i use a map i would use for a sub for a comp. im thinking of getting a pair of 6.5" Pheonix Gold RSD's comps and a pair of 6.5" Pheonix Gold RSD's Coxials. Could i run a Kenwood 7202 stereo amp to the comps and tweeters? I just dont understand how to wire them up, cuz its not like a dvc sub. basically i have no idea what im doing. enlighten me! thx
Kenwood KAC-7202 specs:
* two-channel car amplifier
* 150 watts RMS x 2 at 4 ohms (230 watts x 2 at 2 ohms)
* 460 watts RMS x 1 bridged output at 4 ohms (4 ohm stable in bridged mode)
* high-pass (12 dB per octave) and low-pass (24 dB per octave) filters variable from 50 to 200 Hz
* selectable bass boost (0-18 dB at 40 Hz)
* MOSFET power supply
* Tri-way capable (Tri-Way Crossover required)
* preamp- and speaker-level inputs
* preamp outputs
* fuse rating: 40A x 1
* 8-gauge power and ground leads recommended — wiring and hardware not included with amplifier
I also own a Kenwood KAC-8402 4ch. Amp
* 4-channel car amplifier
* 60 watts RMS x 4 at 4 ohms (90 watts x 4 at 2 ohms)
* 180 watts RMS x 2 bridged output at 4 ohms (4-ohm stable in bridged mode)
* front channel high-pass filters (50-200 Hz at 12 dB per octave), rear channel high- and low-pass filters (50-200 Hz with 12 dB/octave high-pass and 18 dB/octave low pass)
* bass boost (6 dB at 90 Hz), channels 3 and 4
* preamp outputs
* preamp outputs
* preamp outputs
