comments on future set up!!!
netherland24
camry
alright well it wont be hooked up for another 4 weeks or so but i started my order and all today.
which of these would u go with as far as HU wise, i have these all in my possesion
- Alpine 9815
- Alpine 9831
- Eclipse 5444
- 2 L7 Kicker 12's New dual 4ohm
- Viper 2500.1 wired at 4ohm to get 1500 watts
- Alpine 545 (05 model) 4 channel amp
- Next audio ALS16-com components up front
- Alpine R type components back
- 100 square feet of mat
also what do u think about a epicenter added?
also which optima battery should i add? be specific..
and what alternator size amperage wise would you guys say is good.
well i am going to be running around 2000watts all together and it has a 130 amp alternator now. but i will look in too a 200+ amp alternator with a yellow top under the hood.
i would look into the 200 amp alt before the battery. i'm gonna be running an orion 2500D and pg ti500.4 and i have searched but could not find any reason to add an optima under the hood. i'm adding a yellowtop in the trunk, but i don't see the need to pay so much for a battery under the hood.
so a red top isnt gona change anything correct? or a die hard GOLD? casue i have the die hard gold ready to use.
i would just use the die hard. i have asked that question so many times and never got a good answer on why an optima is better for under the hood then a good everstart or something.
IMO a red op will do just as good as a yellow top and is a lil cheaper.....i have a 110amp stock alt with 2 red tops and my voltage is a steady 13v with around 2000w rms daily......4 awg wire....
netherland24
camry
netherland24
dallas
netherland24
Mike Mccabe
