combine 2 subs
You need to be more specific. What subs? What amp? Are you asking how to wire them for maximum output or if you should get something different? Again, be more specific.
the 2 mtx terminators and a crunch 1100 watt amp. n i am asking how to wire them for maximum output.
If they are SVC 4 ohm you should just wire 1 sub to each channel. I doubt your amp is 2 ohm stable bridged so I wouldn't do this. Again, the guy that told you to bridge them is wrong.
If they are SVC 4 ohm you should just wire 1 sub to each channel. I doubt you're amp is 2 ohm stable bridged so I wouldn't do this. Again, the guy that told you to bridge them is wrong.
didnt know his amp or subs. i was just saying it was a possibility.
its a 1100 watt crunch powerzone amp 2 channel bridgeable
your only getting 550 peak per channel. I have a JBL BP1200.1 i will sell you that will easily power those subs
GRANDPA
GRANDPA
Richmond VA
csu87
