color me disappointed
my 2v alpine has 0 issues getting full rms from my AQ1200 or eclipse and neither amp even get warm
I keep sub lvl at +15, so the full 2V signal is going to the amp
Because it is a 500 watt rms 1000 max sub and the amp puts out 1000 watts per channel when run at 2 ohm, or 500 per channel at 4 ohm. The sub is dual 2 ohm coils and the amp is not bridgeable, I think 2000 watts might be a bit much for the sub.
Headroom and clean power is never a bad thing when done properly. I'd be much more hesitant to crank my gains than have more than enough power and keep the gains low.
I might try hooking up both channels tomorrow. I still had to crank the gains on the bigger amp also. I need to mess with it some more. One problem is he doesn't get to keep my big amp : )
Where is your gain set?
little less then 2.5V on my AQ1200, since it only needs like 900 and im at 1ohm. My eclipse i set via dmm but they were louder then i wanted so i turned them down till i liked it from the DMM set gain, which was like 3/4ths, im at half or so
Ok tomorrow I will put the smaller amp back in(if it gets stolen I wont be out so much), disconnect the front speakers, crank the volume to 25, run the subwoofer volume to +15, use this
test tone, with my computer volume all the way up. Now the amp is 400 watts x 1 @ 4ohm so that is 40 volts ac at the speaker outputs, correct? So turn the gain till I see that #?
What about the bass setting on the deck, I think it goes from -10 to +10, what should I set that to?
Ok tomorrow I will put the smaller amp back in(if it gets stolen I wont be out so much), disconnect the front speakers, crank the volume to 25, run the subwoofer volume to +15, use this test tone, with my computer volume all the way up. Now the amp is 400 watts x 1 @ 4ohm so that is 40 volts ac at the speaker outputs, correct? So turn the gain till I see that #?
Subwoofer setting (I believe the website calls it that so the deck should call it that too) should be max +
the number you find while turning up the gain with a DMM is
Square Root(ohms*rms)
IE: (1ohms*1000rms) = 1000 the square root of 1000 is 31.6 so you set it to 31.6 ACV
husker77
husker77
Nebraska
dragnix
