Code Alarm, 95 Maxima?
some you may not use...but wiring diagram will help you alot.
BTW....here's my 4th Gen //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Here you go man:
12volts
wht/red - wht/pur
ignition harness
Starter blk/yel - blk/wht + ignition harness
Ignition blk/wht - blk/red + ignition harness
Power Lock lt. green/red - in drivers door at switch
Power Unlock green/yellow - in drivers door at switch
Lock Motor brown/white in drivers door at switch
Unlock Motor brown in drivers door at switch
Disarm Defeat brown in passenger door at switch
Parking Lights+ red/green steering column
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal®
Door Trigger red/white - low in drivers kick
Dome Supervision
Trunk/Hatch Pin purple/yellow - drivers kick or BCM
Hood Pin yellow/black - BCM
Trunk/Hatch Release purple/yellow - low drivers kick
Power Sliding Door
Factory Alarm Arm arms w/ lock
Factory Alarm Disarm disarms w/ unlock
Disarm No Unlock
Tachometer white/green ac ECM
Horn Trigger green/white -
thats probably the worst unit you could ever attempt to learn on. There are sooo many wires on that thing, and you'll only use probably a third of them. Not to mention programming it will not be fun. Built in shock sensor is super touchy, and difficult to set using the remote. The brain is HUGE, and you'll have to program the transmitters to the system.
Good luck with it.
And the only tip I have is read the install manual about 3 or 4 times before you start on it.
You can actually grab most of your wires in the Dr kick. Parking lights,door trigger,trunk trigger and release, and even the brake.
The car is Very simple to do, Ive done a ton of them, although the Code isnt the easiest POS to learn with as stated above.
Yes you will most likely need a relay for the trunk release, IF you have power trunk release. I dont recall if the Code has a onboard relay or not.
sdb318
sdb318
Mont Clare, PA
6spdcoupe
AJ (ACE)
    Jun 28, 2026
