Clipping?
  • 2
Rukuzz
How do I prevent clipping? How can I test for it? Or how can I tell before I do some serious damage to my speakers.
I'm going to setup 2 Jl10wOs on my pickup & I don't wanna mess them up!
//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
To make things a bit easy start wtih your deck. turn it up about 3/4 volume then adjust the gain on your amp slowly till you hear it distort the subs. Back it down 1/4 to 1/2 a turn..After that never turn the volume up on your HU past 3/4 and don't use bass boost on the deck or crossover. That should be enough to keep your subs from getting cooked because there will be no distorted signal input from the deck and you won't be pushing your amp to clip.
Mike
I would assume they are pretty accurate as long as they are directly tied into the clip circuit on the amp. Having said that, the signal traveling...
11
771
Don't recall off hand. Both single dins. One excelon, one not.
944
1. make sure you wired your subs right... https://jlaudio.zendesk.com/hc/en-us/articles/204374200-Dual-Voice-Coil-DVC-Wiring-Tutorial 2. set...
10
Even a basic TL072 will do this function just fine. LoL. The joys of comparators!
34
6K
I would pull the HU and bench test it. Can be done with a 12v battery on a non-metal work bench easily enough.
16
Rukuzz
Rukuzz
McAllen, Tx
Rukuzz
1aespinoza
    May 23, 2024
Doxquzme
    May 22, 2024
