class D amp for two 15' L7's?
titze58
ive been doing some research on class D amps and the only negative thing i have found is in the lower accuracy of response tme. i'm looking for advice from someone with experience with these amps.
Also, probably a dumb question, my speakers have dual 4 ohm voice coils. i have each speaker seperately wired in parallel to produce 2 ohms. i was told by an experienced member, with this setup i need an amp that will run at 1 ohm stable. Is this correct? I am just looking for the best way to setup these subs and to understand how it works. thank you for your suggestions.
and want to clarify on this, the response time won't change, power is power, just class D amps are way more effecient, so less draw on your charging system...better for subs...
the kicker kx 1200.1 puts out 1200 rms. Is that 1200w to each speaker or is that split because the speakers max at 1000 rms?
titze58
titze58
detroit
bdavies11
