Class D amp, but not cea compliant??
The best CERTIFIED test I've ever seen on the BRZ2400 was 1100 watts. What does the SQ do? I don't care about those clipped dynamic test
1149
around the 24 min mark.
I know a lot of people say power is power, but there is a noticeable SQ difference between the two, soundqubed has better dampening.
I have about $500 for a amp/sub bundle. I can make a box. Would that be the best? I don't want used stuff. I only have a 4 gauge power wire. I have plenty of trunk space
Are all sounqubed amps compliant? I'm looking at the Q1-1200 amp with 15" D2 bundle for $440. Is that going to pound for the money?
most underground amps are better built than most CEA compliant amps. Puts out a lot more power at a lower ohm load and is built like a tank.
that bundle is perfect for your budget. You'll need a properly designed ported box, cannot go sealed with this sub. Make sure you have enough clearance, airspace and port area for the highest output box possible.
I want new stuff just because I've never had new stuff. But I'll go check them out. Do u know any amp sub bundle for sale threads on here? Or someone I should pm?
You can get good deals with bundles, but it is not always the case. Just check the sub and amp classifieds for things in your price range. I can't think of any off the top of my head. I know 360Durango is getting rid of a bunch of nice subs
...there is a noticeable SQ difference between the two, soundqubed has better dampening.
Do you mean the soundqubed gets wet better, or that it has better DAMPING?
FWIW - CEA-2006 compliance isn't of much value on a 1 ohm stable amp.
The spec deals with 4 ohm power only.
By the time you drop to 1 ohm it doesn't mean much of anything.
95lincdog
95lincdog
portland, OR
Jeffdachef
