Clamped us amps USA-100
kingjd7
I've never clamped anything before so I thought i would try it out The dimm said 44 and the clamp said 6. 6 x 44=264, I had to test everything seperate meaning I had to put each meter on one at a time.I have the subs wired to 2 ohms. Did I do the math proper?
Without watching you actually take the measurements it's hard to say if you used the tools correctly, but it looks like you just discovered that the DC resistance/nominal impedance of your woofer is not the actual load your amp will see at any given frequency.
Start a graph and take the same measurements at 5hz increments from 20-80. Plot that out on some graph paper and you'll see your impedance curve. My guess is that you will not see your 2 ohm number anywhere within that spectrum.
kingjd7
kingjd7
Kent Ohio
hispls
Mike Mccabe
