cl2i not turning off sub
  • 4
Ali2627
Hey! I got a Rockford p300 and I have it set for audio detection. It's RCA connected to my cl2i which turns off and on just fine with the car but my sub won't turn off after being turned on. whats up with that?>
my getto fix is to just tap into the 12v line for the cl2i that turns off and on to the sub's switch input which should do the trick but i was hoping i didnt have too
yall. I unplugged the radio harness and the antenna and plugged it all back in and it works. I guess its fixed… suppose it was the head unit...
820
Perhaps you changed something without mentioning it here? Maybe a loose turn on line? I dunno man...but we'll take it. Hopefully it keeps working. 👍
16
You tried the external relay with no success? If so, how did you wire it?
18
Thank you all for all the replies, I intend to reply to each and every one individually as I test things out. Here's the latest development that...
13
Ali2627
Ali2627
Los Angeles,ca
    May 18, 2024
    May 16, 2024
