Chrysler 300 Big 3 Help Please. *pics attached*
  • 2
znewberry
Illinois
2013 Chrysler 300
I understand running the big 3 isnt of much help on these cars. however I have enough 0 gauge and would like to do it. I havent found any good videos or guides for this car probally because its not much needed.
[Question 1]
The factory power splits into 2 on both ends. In the trunk it goes to a fuse box and also travels to the alternator and another fuse box / positive post. Do I run the 0 gauge to the fuse box/positive post and alternator? or just from battery positive to alternator and ignore the fuse boxes? Also can I just attach my new 0 gauge to the wing nut on the termials I have leaving the current setup intact aswell?
https://ibb.co/iNhV46
https://ibb.co/fXtgBm
[Question 2]
What is this wire to the right that loops up? the one that goes south is battery power to alternator. is the second one a ground of some sort?
https://ibb.co/gS3sHR
Big 3 consists of the following:
1) Alt Charging post to battery +
2) Engine to Chassis (this helps alt ground)
3) Chassis to Battery -
Thats it. Leave your factory wiring, just add Big 3 wiring too it
Edit: here a vid that might help
Personally, I solder all my terminals over a crimp
Thank you, Can I attach the 0 gauge to where I have my red arrow pointed?
https://ibb.co/ncDgBm
Thank you, Can I attach the 0 gauge to where I have my red arrow pointed?https://ibb.co/ncDgBm
yup. Do both terminals tho. You can get away with factory terminals if you have a single run of 0 g running to the amp. Otherwise, it gets crowded quick.
Edit: That looks like a Hefty factory ground. what gauge wire is that?
i can see how it would get crowded quick. I see upgrading battery post in the near future with more batterys ect.
much appreciated!
This Is a NIB amplifier, one of two that I was to use. Decided to go class A/B on the front mids and tweets and just purchased a Helix B FOUR...
Good thing its under warranty and that you have contacted A.Control about the issue so it has been documented. It will help speed up the return...
Wow, kinda baffled here. Once you get the tune right. You don’t need to mess with it. However, A bad tune you will. You may have different type...
16
774
znewberry
znewberry
Illinois
znewberry
Brendon Jenness
    May 8, 2024
    May 8, 2024
