choosing an amp for subs
DetLion04
im purchasing 2 forsgate p2 15" subs with the following spec.
15"
8 ohm voice coil
250 RMS / 500 Peak power handling
60 oz double stacked motor assembly
2" anodized aluminum voice coil
8 AWG speaker terminals
i am wondering what will i need my amp to have in order to receive quality power to power the 2 subwoofers
would my current kenwood amp work without losing any power to the subs
• MAX POWER 1000W
• Class D Amp
• Variable LPF
• INFRASONIC FILTER
2 Ohm@14.4V 500 Watts × 1 (100Hz, .8%THD)
4 Ohm@14.4V 300 Watts × 1 (20-200Hz, .5%THD)
Infrasonic Filter 15Hz, 25Hz, -18dB/oct
Low-Pass Filter 50Hz-200Hz (Variable), -24dB/oct
Maximum Output Power Watts
RMS Power Output 300 Watts × 1 (1%THD+N) (4Ω)
Signal-to-Noise Ratio dB
• MAX POWER 1000W
• Class D Amp
• Variable LPF
• INFRASONIC FILTER
pay attention to the 4ohm rating only...this is 200 watts less than you need
im sorry man i appreciate your help but i just cant seem to understand this, let me take another run at it!
when searching for amps i want to look for amps with 500 watts RMS x 1 at 4 ohms... and if i find one with these secf. ill be okay?
exactly...when trying to power speakers/subs/whatever, always look at the rms or continuous rating...DO NOT PAY ANY ATTENTION TO MAX/PEAK ratings.
one more question...
would you agree with this diagram when hooking up the system?
haha!! im sorry but i will not cheer the lions until fall of this year... i paid 550 installed for 2 12" p2s with kenwood amp, but im selling that system and looking at 2 15" p2s
DetLion04
DetLion04
detroit
KINGDELL91
vegang
vegang
