Chinese subwoofers
guys those things that yo are calling screw holes on the first subs are there for looks look closely at it and youll see the mounting screw holes near the surround
And if you look even closer you will see that those screws hold the surround on and you are wrong.
BAWAA HAHAHAHAHBAHA!!
For looks? As I said much earlier in the thread, that sub frame is made of parts that are bolted together. Those holes and bolt heads you see are not just for looks. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Never seen a design like that before. Very interesting.
Oh, and did you see the amp;
C-2000 High-Performance Car Amplifier of Long Life Span
That's funny. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
http://honsound.com/sort.asp?sort_id=4&sort_name=Subwoofer
the new wood colored and the new RED one...//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
Just a little FYI
why in the hell would you want to put a spider/suspension setup behind the motor like that
all it does is add moving mass...and cost...for no extra performance (ie they are still using a off the shelf surround)...other then a marketing gimmick...which it's doing that well...it has you all talking
It make cone movement extremely linear at high excursion, there are alot of subs that use spaced apart dual spiders to achieve this, Pheonix gold and Memphis audio's LVS sub have this.
more spiders do not mean less deflection
if you know what your doing you use the motor to control the soft part arrangement, and use less suspension and mass...ie: jbl WGTi
stones
Senior member
stones
Sask
negativezeroz
