Chevy Restoration.
UPDATE!!!!
Got it up on the rack today and started stripping it down.
I got the bed, pass side fender removed.
I then started shaving the antenna on the pass side fender.
Got it all welded up and ready for a coat of glaze and primer.
lookin good, should be nice and clean when its all done. Fresh paint is soooo nice to look at //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif Only problem is it makes you wanna baby your truck sooo bad lol. Even the thought of driving down a dirt road will give you nightmares lol.
Ok Got the cab corners and rockers glued in. Had to make new backers for them also.
Used the stud gun and got 95% of the damage to the front of the door out. Filled it and also fixed a couple other dents while I was at it. Then sprayed some primer on it and guide coated it.
After blocking, filling, blocking, filling, blocking, filling again and again my arm fell off:luke: But the dented pass side fender was ready for primer!
After Primer dried, I blocked it again and found 2 more small dents that got filled. Another 3 coats of primer were sprayed and now it is ready to be edged in and wet sanded for paint.
Also got the driver side fender blocked and primered. I will get it blocked and primer it again maybe today so it will be ready to edge it all in at the same time.
Got some new pics today finally coming together. decided to cut n buff it but that hasnt been started yet. looks good few imperfections here and there that the cut n buff will fix. lookin really good just a couple fitment issues with the drivers side fender got flatened out a bit but should be fine. hopefully ill have the exterior completely done and back on the road by friday if parts come in on time! let me know what you fellas think
and a picture of my next upcoming project.
YIIIKES
jeeper07
Rebuilding&Reconstruc ting
jeeper07
Indianapolis, IN
jeeper07
