Chevy Malibooty build log lol 12" setup
solidcrowd
Let's get this thread started! Enclosure is 2.5cuft @ 32Hz (4" Flared Aero Port) after displacement. Design courtesy of Bromo from Car Audio Forum - Car Audio's Forum!
Cut Sheet drawn out.
Making sure everything lines up.
Box taped together
Screwed, Glued, and Sealed
Bottom
Top View and 4" port hole cut
Port Cut to Length
Aftermarket Battery Terminals Installed
Trunk Layout Design (hopefully)
False floor cut and Laminated
1st layer of Primer
And this is all that is done for now! More to come very soon. Subscribe if interested //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
that box is way two small! //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
cool build, tuned in
Update....Subwoofer is 12" SI Mag Claw V1 (V3 softpart recone) with another custom dustcap lol. Bought if off my friend for $100 because his dog dented the dustcap. It has only been played for an hour after the recone. He's not into caraudio and doesn't realize he basically just gave this gem away lol.
Dented Dustcap
Dented cap off
Fixed :)
Screwed in
Side view
Wired to 4ohms
Updated trunk layout
Door Speakers, Bravox Audio CX50Ks
12.5 sqft. of AudioWrap (Review coming soon!) Then buying another roll for trunk
Lemme know what you guys think.
UPDATE: Finished product below...for nowww //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif lol Building a 2.0cuft @ 33hz in the spring. Along with doing the Big3 and adding a battery in the back.
What you guys think?
Just an fyi, a 4" aero isn't enough port area for a 2.5 cube box. Everything else looks great though. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Yea I worked at Tontine Carpet One for my first job. I always go back in there and pick up leftover supplies. I glued it down to 1/2" playwood. Works for a perfect false floor and looks clean.
I had a '99 Chevy Venture with the 3.8 and buddy had one with the 3.4. Any of those engines including the 3.9 are known to leak coolant at the...
791
You can raise the back sea approx 2 inches and get a front firing enclosure for two tens in there ported center. Other than that. Atrend makes a...
A lot of guys say I'm going low-end on cost but I see a lot of guys recommending just as cheap or cheaper products. Like MESO-6-5-3WAY-COM //...
13
I would add two more of the same subs and look at selling the 2k to go towards the funds of a decent 5-8k mono amplifier and new enclosure
solidcrowd
solidcrowd
Buffalo, New York
bigbangtheory
Decebal
    Jun 10, 2024
