Cheapest amp for between 1200-2000rms
detroitdiesel
Hello, i am looking for the cheapest amp that will run around 12-1500wrms at a 2ohm load. The amp will be powering 2x pioneer premier pro 3002D2 subs rated at 1000wrms/3500wmax. I was looking at a Power Acoustic LFA1-5500D, or BAMF 5500 amp. They are reasonably priced and should do at least 1000wrms.
So, just to make sure, the Audiopipe 1500 will run 950w rms at 2 ohm, and if i hook my two pioneers two it with a final load of 2 ohm, they will each be getting 950wrms each?
So if i would only get half the power by hooking both subs up, why would i want the JBL? I would only be getting 750rms per sub, would i not?
Also, i though if you hook two subs to an amp on one channel, they would each get the same amount of power as if only one sub were hooked up. So i am wrong??
detroitdiesel
detroitdiesel
alberta
AARON30
