charging 2nd batt question
can i just put the charge wire to the back batt to the alt??ive seen people always put the wire from the back batt to the front batt. can i directly charge the back batt??
It will still pull from the front batt if they share the same alt. You'd need a sec alt to charge just the system.
For 1-2 rear batt applications, is best to have power/ground wire from the front batt to the rear batt. Also grounding the rear batt to chasis/frame. Then the amp will be connected to the rear batt pos/neg.
If you only want to charge the rear batt while the vehicle is on, then you'd need an iso. The iso can be mounted under the hood or near the rear batt.
What's your electrical consist of?
140 amp alt
100 ah battery
30 2awg for both batts
big 3 in 1/0
2krms amp
back batt ground in 1/0 or 2awg
an i wanna get as much powah as i can with no light dimming.....that shit sucks!!!! i blasted the amp full tilt for 10 mins only with the rear an never cut out once...i think i will b good, but just wanna make sure....im fusing both ends of the powah wire
My bad, posting on other thread. You're most def fine on the electrical. It seems like you might be interested in owning an iso...and I right?
if its not going to melt yes.....i had a soloniod and it melted after like a week, it got stuck in off position....point me in the direction of a good isolator kind sir
any cons of using it?? this looks like the last one i had, i think i only need a 200 amp one....an would i still need 2 fuse the wire with this
yea I went a little over kill, just cause I thought you might be upgrading sooner or later. Lol Cons would probably be manufacture defects or installation error. (guessing)
alright but i think im cool with this system might b too much....an im a man who loves bass but my face an cheeks feel funny wen im in it
so a 250amp would b cool...allowing for a lil leeway
Bad4health
Hymen Removal Specalist
Bad4health
charlotte, NC
Bad4health
