^ channel amp vs. 6 channel head unit
  • 2
little66085
Dumb question. I have a JVC head unit with 2 Sub preouts (L&R). My MBQuart 6 channel amp has 6 inputs for full range speakers. I want to use CH 5/6 for the single sub. The speaker wire to the sub from the amp is bridged between the two. Can I just run RCA cables from the 2 preouts to the 5/6 on the amp, or do I need to convert to mono? Thanks!
It is Opel (Vauxhall) Astra J 2011 model, I change the HU to Kirinavi 10 inch screen. The factory speakers are Infinity and would have come with a...
553
Okay, I'll bite. If you're going to get rear speakers, get the same ones (model type, doesn't have to be the same size) that you have up front...
I would keep the amp you have and keep the components. Place the components in some universal door pods, and look at getting a powered SAS 8"...
13
A 6 channel and a single sub amp would be my choice. Or a 2ch, 4ch and a sub amp. You don't need 2 channels for subs.
880
You can wire those subs up @8 ohms if they are both SVC4 ohm subs,and that amp will run fine after being tuned properly...
little66085
little66085
Chris Gerrish
    Apr 25, 2024
Chris Gerrish
    Apr 25, 2024
