cda-9887 - volume knob has sticky point when cold
oneiztoomany
sup everyone, i've noticed that when my car is not warmed up there is a point at which my volume knob sticks. like it doesn't want to turn and you have to twist with extra pressure to get past that point.
should i return it? does the knob pop off so that i can maybe see whats causing it to stick?
I have noticed mine is sluggish as well, when it is cold, I just use the remote.
I would rather use the remote, than force it when its cold..
Every things expands and contracts with temp. changes... Keep that in mind.
A pretty good amount probably around 150, did you buy the unit authorized?
yes, you're right, its just that the shop i bought it from is trying to say bring it by and they will look at it. well unless i drive there without the heat on the whole way it will be fine by the time i get there.
so i'm not sure how they are going to duplicate the issue...
Ah I hear ya. I'll see if mine does it when I get out of hte office.
thanks,
try turning it with just the tip of one finger, i know, i'm really obsessive compulsive. however its easiest to notice a sticking point, if there is one by doing it this way.
oneiztoomany
oneiztoomany
USA
oneiztoomany
