CD-400 power wire?
  • 2
it depends if you are going to use the internal amp of your hu. i'm not sure about your harness, but the power and ground wires are usually larger than 18 guage, but around 14 guage. if your harness has 18 gauge for the power and ground, then you may want upgrade to prevent a short. if your power and ground wires are around 14 gauge, you may not see a difference since the hu is designed to work on stock wires unless stated.
Is there an external fuse mounted near that amp going to it? If so, make sure it is not grounding out some how. Frayed wire touching ground or...
The Timpano amps are also small. I bought a small 1400 watt Timpano mono amp. I was impressed by the power I could get from it, but they have a...
15
  • Locked
Alpine PKG-M780 Headrest Video Package Dual 7" LCD video monitors pair of 7" LCD video headrest monitors mounting kits connection box 2 pairs...
https://www.amazon.com/gp/product/B0016G4EXQ/?tag=caraudiocom-20 https://www.amazon.com/gp/product/B07BMT699G/?tag=caraudiocom-20 Im not a fan of...
Garland
Garland
Boston, Ma
boister77
    May 12, 2024
Brendon Jenness
    May 11, 2024
