CarPC setup, need experienced advice.
Tripwire
Purple Monkey Dishwasher
Here's a quick diagram I drew up in paint... just wondering if one of you guys could verify my plan here.
Tell me if you see anything that needs adjusting...
And a link to the Amp...
http://www.sonicelectronix.com/item_368.html
One more thing, can I limit the Amp's output to the 4 channels for the speakers? Would that be necessary? The amp puts out 55wrms and the speakers are only designed to handle 50wrms each (although I hear they can handle more). Suggestions to fix this, or should I just keep the volume down a little? //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
I have no idea on the car PC set up, but with that amp, you can set it to 50 RMS with just the gains. Some of the Hifonics amps have been know to be overrated, so you might not even have to worry.
Theres some tutorials on setting the gains on the forums, for when you get there. It's actually quite easy. You can make it at 20 RMS at full volume, with the gains, so there's no need to worry about that.
GL on your car PC tho!
Thanks for the help, now I don't have to worry about cheaping out on my amp's power for sake of saving my speakers. =D
The next thing I need to worry about is volume control between the carPC's output and the Amp's input. Still trying to find out more about Equalizers and Pre-amps.
Tripwire
Tripwire
Virginia
Tripwire
BP1Fanatic
BP1Fanatic
