Joe89
I know this will not be the correct way to do things, however...
I would like to listen to my Eminence Beta's and ST350's before I install them in my vehicle.
I have some passive crossovers for Memphis PR 6.5" component speakers.
I am aware that crossover points are impedance dependent, but given that the Memphis 6.5" speakers are 4ohm, and I can wire (2) Beta's in parallel to 4ohm, (same case for the Memphis tweeters and ST350's), will I be okay testing the speakers (with low wattage) in this manner? In my vehicle the speakers will be run with an active crossover.
Edit: Just realized the receiver I am using to power these is only stable at 8ohm. Anyone have any ideas? Can a set of useable crossovers be found at Radioshack or Fry's for cheap?
Edit2: I suppose I will turn this into an educational project and attempt to build my own passive xo's. http://www.parts-express.com/resources/building-a-crossover.cfm I will be following this guide. Now, I have to see if I can source the necessary capacitors, inductors, resistors, etc locally...
