Car won't crank
bibby
I installed 2 jl10w0's and an 300w mtx amp, and all wiring in my friends 99 dondge intrepid es. I used an inline converter to convert the speaker signal to RCA. grounded the amp to the radio's antenna bracket in the trunk, and wired into the switched wire on his factory deck for the remote. Everything worked fine for a few days, now the car wont crank, It acts like the battery is dead b/c it clicks. When you jump it off, it will run for a few seconds, then die. Any ideas?
no DMM to check voltage. Maybe it stayed on, but after you jump it, it shouldnt just die b/c it will run w/o a battery.
if it clicks that means u need to let it charge some more, let it charge for more than 2mins.
clicking isnt the problem, the fact it dies, and doesnt have enough time to charge is the problem.
I'm thinking it sounds like the alt. We are unhooking everything, and putting it back to stock, to see if that works.
probably the alt went bad or maybe a short looks like its the alt tho //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
bibby
bibby
none
bibby
