Car AV noob here, could use some help before I complete this purchase
  • 4
WyattCarden
Currently I am running a setup of two 12s in my car with a Pioneer GM-D8601 1600W amplifier. I don't believe it is enough power, which is a reason I could use a recommendation for a better amp.
I could use some help picking out some new stuff:
6-3/4" component speakers for my doors
new 6 x 9 speakers
new amplifier that has the ability to power everything.
Thanks!
I am looking to upgrade my component speakers in my doors, as you can see, my back 6 x 9 speakers, replacing the radio with a newer one, and need an amp that will suffice for everything. Budget is about $500
Rear speakers are pretty worthless. A proper sound stage should be all up front with sub bass filling the cabin but centered up front.
Basically focus on the front. If you are at a concert the band is infront of you.
Stop looking at max ratings, they don't mean anything, your amp is 800 watts not 1600. Look at RMS but be careful, like I said if it looks to good to be true it is. They can put whatever they want.
new 6 x 9 speakers
Thanks!
Are you sealed or ported on that box? What 12's? That 8601 doesn't have subsonic filter.
Almost all brands operate the same way. Alpine, Pioneer, Kenwood. The technology is based on what sounds it can produce. Basically all brands...
340
I do not see a problem with an addition of up to a 600 RMS Class D mono amplifier with 4 ga OFC wiring supply kit and be fine. It would be...
10
470
WyattCarden
WyattCarden
Goodrich, MI
CSCStang
    May 12, 2024
Brendon Jenness
    May 11, 2024
