Car audio help
pics of the speaker install? you need good seals at the speaker.
example of a speaker install:
adapters painted, T-nuts used for driver mounting. foam used to decouple baffle from door, on the back of the speaker between the baffle, and on the front of the speaker to seal it to the factory panel.
also, foam was used on the back of the midbass, and speaker terminals were heat shrunk.
Brandon Garlick
Brandon Garlick
los angelas, ca
keep_hope_alive
