imbored408
The wires are connected to the terminals permanently. The only way I could remove them is if I cut the wires off. The negative ground wire has no slack so I wouldnt be able to connect it to a new terminal if I had one.
I do not want to mess with the positive one for the same reason.
Would it work If I just unscrew the nut and slide the ring terminal on the bolt then tighten it back up with the nut?
