Sold Car Audio Goodies For Sale.
JohnnyB4439
Live For This!
Hello everyone, I came across this site the other day and I really like all the information and help you can get on here. I thought I would post my car stereo stuff I have, the only reason I want to sell any of it is because I want to save up money for a new Pontiac GTO. Take a look and let me know if your interested.
15 Inch Kicker Solo Baric L7: Dual 4 Ohm (S15L7)
Kicker Solo-Baric L7 Series
15" subwoofer with dual 4-ohm voice coils
SoloKon aluminum-treated composite cone with Santoprene surround
Cast-aluminum basket
Power range: 50-1000 RMS watts
Peak power: 2000 watts
Frequency range: 18-100 Hz
Sensitivity: 88.5 dB
Mounting depth: 8-3/16"
Sealed box volume: 1.5-6.00 cubic feet
Ported box volume: 3.0-6.0 cu. ft.
Audiobahn Mono Amp (A8000T)
Class A/B MOSFET Circuitry
PWM MOSFET Power Supply
Semi-Double Sided Glass Epoxy Circuit Board
THD : 0.02%
S/N Ratio > 100dB
Frequency Response : 10Hz - 40KHz (+ / - 1dB)
Variable 18dB High Pass Crossover : 50Hz- 750Hz
Variable 18dB Low Pass Crossover : 50Hz- 120Hz
Bass boost on / off
Subsonic Filter :20Hz - 50Hz
RCA Throughput Connections
3-way Protection Circuitry : Thermal, Short Circuit, Overload, Cooling Fans
Cobalt Blue Illumination
High Gloss Chrome Plated Finish
Nickel Plated Block Terminals
Air Induction Fan Cooled
RCA and Speaker Level Inputs
4 Ohms Mono : 400W x 1
2 Ohms Mono : 800W x 1
Dimension(H x W x D) : 1 7/8" x 9 7/8" x 11 7/8"
MTX Thunder 8302: 2 Channel Amp
Amplifier Type Dual Channel
Bridgable Bridgable
RMS Power at 4 Ohms 75 W x 2
RMS Power at 2 Ohms 150 W x 2
Performance
Frequency Response 20 Hz - 20000 Hz
Signal to Noise Ratio 110 dB
THD at Rated RMS Power 0.1 %
Crossover / Equalizer
Bass Boost With Bass Boost
Bass Boost Frequency 40 Hz
Low - Pass Frequency 40 Hz - 200 Hz
High - Pass Frequency 40 Hz - 200 Hz
Other Features
Input Voltage 12.5 volt
Dimensions
Width 9.75 in.
Depth 11.5 in.
Height 2.1 in.
Miscellaneous
Product ID 20289985
More Information
The MTX Thunder 8302 has 2 Equalizer Bands. Signal to Noise Ratio: 110 Decibels.
MA Audio Line Driver (MA100B)
Black Chrome Finish
Frequency Response: 40Hz – 400 Hz
Stereo/Mono Selector
0.2-8V Input Voltage
0.2-8V Output Voltage
Gold Plated RCA Connections
RCA Line Output
Power-on LED
Remote Control Module Functions:
Variable 0-180° Phase Control
Variable Q Control: 2-20
0-18dB Input Level Control
Dimensions (L x W x H): 6.75” x 4.33” x 1.33”
Boss DVD Player (DVD 4000B)
Half-DIN mounting
MP3/DVD/CDR/CDRW & SDVD compatible
On-screen programming
Multi-language display
Last position memory
NTSC/PAL compatible
Wireless remote control
10 inch Stinger Fan (SF3N)
The SF3N is designed for tight fitting places such as amp racks. The low profile, crossflow design is extremely efficient at cooling hot amplifiers. Approximate flow rate is 54 cu. ft. per minute (CFM). Dimensions are 8.125" L X 1.75" H X 1.75" D.
15 Inch Kicker Ported Box
Audiobahn Wiring. 1 Power Wire, 3 different ground wires, 3 sets of rca cables including one pair of twisted pair wires, remote wire, video and audio rca cables and speaker wire. Also included clamps, quick connects, distribution block, 60 amp fuse, fuse holder...the whole nine yards. All the lengths are long enough to run to the trunk with plenty left over, you should not have any length issues.
Everything is in 100 percent working condition! If you have any questions of comments please feel free to PM me, my email address is JohnnyB4439@hotmail.com, or you can instant message me at JohnnyB4439.
15 Inch Kicker Solo Baric L7: Dual 4 Ohm (S15L7) $150 Shipping Included
Audiobahn Mono Amp (A8000T) $130 Shipping Included
MTX Thunder 8302: 2 Channel Amp $75 Shipping Included !!SOLD!!
MA Audio Line Driver (MA100B) $60 Shipping Included
Boss DVD Player (DVD 4000B) $75 Shipping Included
10 inch Stinger Fan (SF3N) $15 Shipping Included !!SOLD!!
15 Inch Kicker Ported Box $50 (Local Only)
Audiobahn Wiring. 1 Power Wire, 3 different ground wires, 3 sets of rca cables including one pair of twisted pair wires, remote wire, video and audio rca cables and speaker wire. Also included clamps, quick connects, distrubtion block, 60 amp fuse, fuse holder...the whole nine yards. All the lengths are long enough to run to the trunk with plenty left over, you should not have any length issues. $50 Shipping Included
JohnnyB4439
Live For This!
JohnnyB4439
St.Louis
JohnnyB4439
