Sold car Audio F/S
Disco Nate
Car Audio For Sale
Thunder1501D $200.00
Specifications
RMS Power 12.5 VDC Input
Low Level Input
Crossover(s)
Low Pass @ 40Hz-200Hz - Variable
Compression Circuitry
Thunder EQ
EBC2 Port
RCA Output
Low Pass Only
2 Ohm Load 1000 w x 1
4 Ohm Load 500 w x 1
Dynamic Power 14.4 VDC
2 Ohm Load 1500 w x 1
4 Ohm Load 750 w x 1
Dimensions (with ISO Feet)
17.8" x 9.75" x 2.1"
45.3cm x 24.8cm x 5.3cm
RE Audio® SE15 15" Dual 2-Ohm (4 total) $500.00
 Dual Composite 2-piece Cone
 Rubbertek Foam Surround
 Cast Aluminum Basket
 3" 4-layer Aluminum Voice Coil
 FEA Optimized Motor Structure
 Triple Stack Maganets
 Progressive Spiders
 Wrap around Rubber Gasket
 600W RMS
 Dual 2 Ohms
 Mounting Depth: 7.75”
__________________
Sub Chaser Vol.1 Cd Now Available For Sale At These
Available Locations Or contact me direct @ (813) 363-8527/omgcarstereo@gmail.com
1. Divine Sounds 8338 N.Dale Mabry Hwy. Tampa,(813) 886-3100
2. http://www.myspace.com/nateharrisfilms
3. 2Extreme Audio Plant City, (813) 707-1448
OMG Custom Car Stereo
Disco Nate
Disco Nate
Tampa, Fl.
Disco Nate
