Car Audio Equipment Recommendations.....
b1utigg3r2
Now my mind is set upon these equipment below...
Head Unit: Alpine CDA-7878 ($450)
Subwoofers: *2* 12" Digital Design 3512a ($500)
Amplifier: JBL BP1200.1 ($300)
Please tell me if this is a good start for a stereo system... I'm new in to car audio, but I've done some research and got some advice on what to get. Please post a reply telling me what is good, and if these products are worth the price. Thanks~!
I was wondering if I were to get the pair of Digital Design Subwoofers (12" DD3512a), I would only be able to hook one subwoofer to the JBL BP1200.1 right? If I'm thinking right, then the amp is a 1-channel? The DD3512a takes 600W RMS and the JBL 1200.1 puts out 600W x 1 (4 ohm). That's max power towards one sub right? Please tell me if I'm thinking correctly... Thanks~!
get 2 dd dvc 2 ohm voice coils and wire it in a series parralle config would = 2 ohms mono. you should be tight then=) headunits vary in taste looks like you have your mind set. i would suggest a mids and highs amp and some speakers to "try" to keep up with your boom lol
Im pretty curious as well.I am wondering what all took place for the supply for the demand?
873
if you can read a simplistic book you can follow the directions to put together just fine. Its not rocket science. If you have questions about the...
503
16
Does you car have the noise cancelling mics from the factory? Usually right above the drivers door. If so, snip the wire to one of the mics to...
13
733
b1utigg3r2
b1utigg3r2
Silver Spring, MD
audiolife
    May 24, 2024
