Car alarms. wha??
Its like a rubber band with a weight in the middle that has a magnetic pick up below it and when vibration causes the metal weight to move, the pick up senses it, causing the alarm to go off
Its a shock sensor that senses vibration
To make it simple, subs vibrate and so do shock sensors on alarms
We have an edit button //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
Whats the physics behind car alarms going off when you turn your system up //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif , just curious. I thought car alarms were pressure activated.
They are pressure activated. The sound waves from the sub cause pressure to be exerted on the alarm sensor.
Duh.
Right there you just stated that sound waves have nothing to do with "pressure."
...Interesting.
...Interesting.
Well i wasn't sure, i always thought the way alarms go off is by the tiny tremor(which could possible be not a tremor at all but the actually sound waves:emb:) you feel on the ground when someone rolls by. But today after class as i was walking to my car, some beater with a system( roadmaster im guessing seeing all i could hear is the rust falling off the frame) set off a car alarm near me.
with my new setup, i set alarms off 200 feet away in a starbucks and davidson drugs parking lot from the main road that I'm driving on //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
has happened multiple times with cars from the same parking lot. so everytime i get near there, i have a habit to turn it up for a few seconds and everytime i see blinking lights and hear the sirens.
thought id share, cuz it only happens in that area so often. weird
thought id share, cuz it only happens in that area.
You must rollin' wit da Roadmaster PFM 18's? Right?
not bad bud. but only 200 feet?!? i set my buddys car alarm off at work around 400 feet away
edit, got to love them audioques //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
i don't know how far away i initially set them off from //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
until i hear it when i turn it down at the near by light, then see the parking lot and the blinking lights haaa
LouDEnougH?
Taste The Rainbow
LouDEnougH?
Buffalo, NY
Eugenics
