caps
  • 2
jeffrich21
i have a monster cable cap .5 farad. i git two question on top of the cap there was a grey plug in it i pulled plug out i guess that was the vent hole that they said should not be cover up or blocked next thing is when i charge it up do i from the the battery or can i do it fron the trunk with power cable, one more does it matter if cap is standing or lay down.
thank you:confused:
if the plug is a vent hole then you did the right thing. Two charging from the trunk is easy enough.. you will need either a small resistor and a test light or just a test light.. Make sure the grounds are hooke up on the cap then add the resistor if you have one under the positive side. before you put the input power to the resistor put the test light clip on the pos terminal of the cap then touch the power to the resistor and the other end of the test light..It will take about a minute.. when the test light goes out then the cap is charged..Third the cap can be upside down and backwards if that is how you want to mount it..it is sealed the vent is just to dissapate heat and will not cause the cap to leak.
Mike
I did an adire koda 8 for now but I'm considering swapping it to a Dayton ho 10. More cone area for more midbass. But I might not need to. I might...
16
I've been very happy with my jy battery, but I likely won't buy another jy product. It irritates me they discontinued their hp40 battery...
jeffrich21
jeffrich21
jeffrich21
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
