capacitor installation
  • 4
arty
Greece
hey again guys,
i was wondering how to connect a capacitor
right the the installation is as follows:
from battery positive to cap positive
from chasis to cap negative
from cap positive(output) to both amps
and from cap negative(output) to both amps
is this ok
or should i connect only the positives to the cap and leave the rest to the chassis
Forget the cap, its useless. Your better off putting a battery in back. But if you really feel the need to have one, the way you said to connect it is right.
you can also ground your amps straight to the chassis, you don't need to ground them to the caps, although you can do it that way. You can also use a distro block for all your grounds.
The amps are not fused themselves. I am considering using smaller gauge wire for the 200 and 300 watt amps (I believe they only recommend 12 awg...
Going all Knu for wiring, lugs, and fuse holders. Been using them for the last serveral vehicles and love their products. Battery terminals...
arty
arty
Greece
GAM3OVR
