capacitor installation
arty
hey again guys,
i was wondering how to connect a capacitor
right the the installation is as follows:
from battery positive to cap positive
from chasis to cap negative
from cap positive(output) to both amps
and from cap negative(output) to both amps
is this ok
or should i connect only the positives to the cap and leave the rest to the chassis
you can also ground your amps straight to the chassis, you don't need to ground them to the caps, although you can do it that way. You can also use a distro block for all your grounds.
arty
arty
Greece
GAM3OVR
