Cap With Low Voltage Cutoff
spentfromnz
NZ
Are there any digital caps that have a low voltage cutoff, ie cuts power to the amp when the battery starts running low? A lot of caps I have seen have a low voltage warning beep, but I think that would be hard to hear over the subs.
Says the guy who doesn't even know how to hook up an amplifier:rolleyes:
//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif:laugh://content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif:laugh:
Get a dash mount voltmeter and turn the volume down if your voltage drops. Works for me //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif Add a 2nd batt that will help alot too.
Where are you measuring the voltage? Upfront or at the rear?
I could have commented on his stellar subwoofer enclosure building ability but I figured why kick a man when he is down.....
ahhhh i think caps are bad too....ive seen a cap cause a voltage drop in my friends car. dropped .7volts from adding a cap.
In my experiences, adding a 2nd batt or any type of charge holding device is gonna drop your idle voltage a little, but it wont drop near as much when playing full tilt. Mine dropped .2 volts when i added a 2nd redtop, but i dont get any drops at all when playing music, except on certain songs that have the higher notes.
You're not saying that with a load it will still be .2v down with an extra battery?
//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif @ kicking chase while he's down
Following chase007's advice is akin to the blind following the stupid! Although, I will admit that he is quite good at regurgitating what he has read, even though he probably doesn't know the reasoning behind what he is saying:crazy:
spentfromnz
spentfromnz
NZ
spentfromnz
