can you mix svc with dvc.....
Well......if it's the exact same sub, and one is DVC 2 ohms, and the other is SVC 4 ohms, theoretically you could wire the DVC in series and each sub will have an impedance of 4 ohms...but if you have different model subs, I'd advise against it, plus I cant think of any subs that have the exact same models, only one is DVC and one is SVC....personally I would never do it.....
Originally posted by Gauntlet Well......if it's the exact same sub, and one is DVC 2 ohms, and the other is SVC 4 ohms, theoretically you could wire the DVC in series and each sub will have an impedance of 4 ohms...but if you have different model subs, I'd advise against it, plus I cant think of any subs that have the exact same models, only one is DVC and one is SVC....personally I would never do it.....
they are the exact same sub, i know they arn the best but i got 2 mtx thunder 6000 dvc and one svc
Is the SVC and the DVC the same rms rating? Even if you have the same resistance with each coil, the DVC will be getting twice the power as the SVC. That is what I am seeing.//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
and what kinda amp set up are you gonna have these on?
to make this work right wouldnt you need...at least 2 amps
1 for the 2 SVC
and a seperate for the DVC
or a 4 channel amp with 1 channel to each VC??
or 3 seperate amps all together?
spiffy182
spiffy182
utah
Mac11
