Can underpowering subs ruin an amp?
tjmortenson
I had a cheap SSL 300 watt max amp, I believe it was 100 watts rms, powering two 12 inch subs that are 300 watts rms each. So 600 watts rms from the sub, but the amp could only provide 100 watts rms, and I had it bridged and running 2 ohms, and the amp burnt out, literally with smoke. I checked for shorts in my wiring and there aren't any, 12.2v with the car off, and all the audio is hooked up correctly. I need some help with this, as I didn't think an amp could be hurt from not being enough watts. But I guess it might be from being wired 2 ohms.
Oh yes it can
I had a little better system in my car, 2 12 Rockford P3s ran by a POS Boss PH3000d. The amp was maybe putting out 500w rms and each sub can do 600w rms so i was down 700w. Before too long the amp blew because it was trying to put out too much power. Car audio is something you cant go cheap on, you seriously get what you pay for
Oh yes it canI had a little better system in my car, 2 12 Rockford P3s ran by a POS Boss PH3000d. The amp was maybe putting out 500w rms and each sub can do 600w rms so i was down 700w. Before too long the amp blew because it was trying to put out too much power. Car audio is something you cant go cheap on, you seriously get what you pay for
The amp probably blew because it was a "POS Boss PH3000d" not because it was under powering the subs. Unrealistic expectations damage more equipment due to driving it way beyond its electrical/mechanical/thermal limits. An example would be trying to get 1200 wrms out of a PH3000d.
tjmortenson
tjmortenson
Brainerd, MN
Kingstroker
michigan born
    May 14, 2026
michigan born
    May 14, 2026
