Can underpowering subs damage the subs
like said above you will have to clip the sub to death trying to drive the amp to do more then it can, under powering causing damage is like saying I can't listen to my system half way up because the lack of full rms will damage them so it's all or nothing! .........................at least that's the line I will be using from here out.
Another great way of putting it haha. And it really does sound silly when you put it that way.
If you dont put enough power to them, they won't have enough excursion to cool and then fail
Yes, if your amp is sending a clipped signal although the woofer is receiveing 500rms for example at full clipp because the of lack of cooling its approximatelyl like running 1500rms.
Hope this helps
143
16
425
571
837
Joe562MMA
Joe562MMA
Los Angeles , CA
Joe562MMA
    May 18, 2024
    May 18, 2024
