can this box work with this speaker?.....is the port tuned correct?
ghost117
can any1 tell me what my box is tuned to.....demensions are
height-17"
width-15"
dept 14"
port-1.75" high x 12.5" wide x 10" dept
it is a slot port..........i bought it to use it with a soundstream xpro 12" 600wrms that says it needs 2cu.ft and port needs to be tuned to 36hz
can it work.....speaker specs
Diameter: 12"
Impedance: Dual 4 ohm
Power Handling: 400 - 600Wrms
Magnet Weight: 100oz
Frequency Response: 35 - 500Hz
Voice Coil SIze: 2"
Sensitivity: 92dB
Mounting Depth: 6.375"
Poly cotton spider with integrated tinsel leads
UV coated foam surround
Superb tinsel strength
2 layer cone (paper and fiberglass)
Aluminium motor cover
Discrete mount terminals
Cast aluminium basket
Vented pole piece
can theses specs work then???
height-16"
width-16"
dept 18"
port-1.7" high x 14.5" wide x 15" dept
any suggestions on the box specs will be helpful
Are you trying to build an enclosure?
If so then just hit up one of the many vendors or members that can work up a design for you.
If not, then just picked up a sealed enclosure and it will function just fine.
ghost117
ghost117
caribbean
AStovall
