Can someone model a Dayton Ultimax 18" for me?
Firebird 1991
Stroked
I was hoping someone could model my Dayton 18" Ultimax for me. I will be using a Elemental Designs Nine.1 which does around 1400rms at 1 ohm. Here are the specs on the woofer below:
Product Specifications
Nominal Diameter18"
Power Handling (RMS)1,000 Watts
Power Handling (max)2,000 Watts
Impedance4 ohms
Frequency Response19 to 500 Hz
Sensitivity88.6 dB 2.83V/1m
Voice Coil Diameter3"
Thiele-Small Parameters
Resonant Frequency (Fs)19.50 Hz
DC Resistance (Re)4.4 ohms
Voice Coil Inductance (Le)2.22 mH
Mechanical Q (Qms)3.82
Electromagnetic Q (Qes)0.62
Total Q (Qts)0.53
Compliance Equivalent Volume (Vas)7.49 ft.³
Mechanical Compliance of Suspension (Cms)0.10 mm/N
BL Product (BL)23.8 Tm
Diaphragm Mass Inc. Airload (Mms)655g
Maximum Linear Excursion (Xmax)22 mm
Surface Area of Cone (Sd)1,219 cm²
I currently have 2 of them in my house on an iNuke6000 and its just too much to be completely honest LOL. They are in 7 cubes a piece with 20hz tuning in the house.
Figured i would put one in the winter beater (1999 GMC Sonoma Extended cab)
I currently have 2 of them in my house on an iNuke6000 and its just too much to be completely honest LOL. They are in 7 cubes a piece with 20hz tuning in the house.Figured i would put one in the winter beater (1999 GMC Sonoma Extended cab)
I have 2 15's (though sealed) on a Crown X4000, and yes they are intense for HT.
Right on!Dayton Ultimax 15s?
Also nice amp, I wish I had a Crown. Nice step up from the Behringer.
Sent from my iPhone using Tapatalk Pro
Yep Ultimax 15's. The Crown is nuts, class A/B and is easily 50lbs, the transformer inside is possibly the same size as my entire JBL GTX500 car amp. If I crank it up too loud the the lights in the house dim and pops the breaker //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Have you done the big 3 on the house yet lmao...
Lol, I probably should.. If I ever maxed the volume out my wiring would certainly catch fire. I don't think I can get an electrician to come out to my house to run bigger circuits and 2 gauge wiring to my outlets //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
On top of the crown I have an Emotiva XPA-2 (300x2@8 ohm and 500x2@4ohm) and a XPA-5 (200x5@8ohms and 300x5@4ohms) powering my main speakers.
And the Crown is 1350x2@4ohms so If I cranked it I would have 4300Watts going in my living room followed by a fire department visit.
Ive never seen this amplifier before. Can you take a pick of the back? Interesting amplifier.
That cone area is fairly close in your setup. Good luck.
51
4K
Hello!I'm in France and I can't register on Hifiengine for unknown reasons and i need to download the service manuals for Blaupunkt Baden Baden...
Still not convinced? https://gpcaraudio.com/15-dual-high-output-glue-it-screw-it-sub-enclosure/ You can order the box glue and screw kit with...
15
Of course not bro, I'm having my car transported to you for install.. You are the only person I would let touch my car on the planet.. Should be...
16
4K
Firebird 1991
Stroked
Firebird 1991
Eastern Iowa
bigblank69
    May 24, 2024
    May 23, 2024
