can someone help me
scfaust
i looking for box help. i have24" from front to back 41" from side to side 15" high. also that would be max mesurment out side of the box im going to put 2 sheets on top i have 3/4 mdf. also my port cant fire back no room so i might have to do sub up port up maybe in front of the box but it cant be at the bottom cuz my amp racks are going to come up 7 inchs on the box. heres what rust said. (2 LV415s with 5 coils , i would do a common chamber box. 3.5 cubes per sub so a total of 7 cubes and 100 si of port. i would tune around 32-34. it will pick up all the lows =] make the port 25 inches deep) i think i want it tuned higher 34 or so for better #s i woundered if any one could sketch up a box or 2 id like to have more than one to chose from. also my email is scfaust@msn.com ifu want to mail em to me please i need help thanx everyone..............sorry i posted in the wrong place first time
if you are trying to make the box and want to do proper 25" long port then port would have to run side to side (best side to put port facing is passenger in most cases) and subs up. i could sketch out a few boxes if you wanted. but doubt you will get 7 cu ft with all displacements accounted for.
ok i have more room from front to back how much bigger would it have to be to be the right size. i would like a side port and how much would i have to pay. i have 5 or 7 more inchs from front to back. i could also go 1 or 2 inchs higher if i had to i just wanted to keep the box under the seat line
i came up with 41x15x26 and it should have 7.3291015625 space? but i cant figure out the port l x w x d port side beingthe side that measures 26 can some one please help me out i want it tuned 34
scfaust
scfaust
hastings NE
scfaust
