CAN SOMEONE HELP ME! Box designing dilemma
NhustlaR
Below me
Ive got 2 15" mojos for my golf. biggest i can go is 37"long by 20 high and 22 deep. i want it tuned to like 35
I cannot, for the life of me, figure out a plan where i can get my subs and the port to fit on the same face(like i want both subs and port facing up, or subs up port forward.
can anyone have some decency(sp?) to help me out there? i know the dimentions are already kinda small for 2 15"s, but i want it to work.
does this look like theres gonna be a little port noise problem? subs mounted on the top.
37Lx22Wx20H
subs on top port facing forward.
Since the port would run the whole length of the box, it must be a 3" port to get the desired 35hz tuning i want.
Will the small port cause noise with a ton of air moving through it?
the first one .. (34.99htz)the whole length of the box gives you a peak of 5 m/s at ~ 35htz
the second one(35.1htz) 18x5 gives you a peak of 18.5 at ~33
both at 1000 watts
soo im saying the first one
i built a similar enclosure for dabeholder. here is a link to the build with pictures and info. his enclosure was of similar size as well. so it can be done.
check that enclosure out and see if you can figure some thing out, if you need more detailed help hit me up on aim, or just ask on here.
NhustlaR
Below me
NhustlaR
Brockport, NY
PowerNaudio
