diminishedpower
I Like Chicken
Ok, so this is my first ported box design and and i wanted to kno if im correct andif someone could double check me on my thinking and calculations, thanks alot if you'll help. Look at my pick and the lingths should include the calc of 3/4 in mdf. and i figure with thoughs dementions i should have 1.6cf per side plus the .128cf displacement of the subs and the .131 displace ment for the port(including the mdf). the port is 10 feet back. if im correct that set up should b around 41-42 hertz and if im correct i could put 1/2 inch mdf in the port making it a 3x3 port instead of 4x4 droping it to 32 hz, correct me if im wrong. also hears my calculations.
0.159*(((16*(1.84*10^8))/(3212.352*(10+0.823*(16^(1/2)))))^(1/2)) for the 42 hz rating
(0.159*(((9*(1.84*10^8))/(3212.352*(10+0.823*(9^(1/2)))))^(1/2))) for the 32 hz rating
this box is for a type-r 12 inch sub. thnx a lot ask any questions if you don't get what i siad, thnx
