can my CVR 12"s handle this amp?
well if you don't turn it up all the way yes and it depends on the ohm you run them and thats 1200 max from the amp right? whats the rms of the amp for the ohms that you are planning on putting through it?
if it is the AUDIOBAHN A12001DT , i just looked up the specs on it and i would have to say that if you run it in two ohms which it says it puts out 750watts at 2ohms and i'm guessing is max power not rms becuase the specs i saw didn't say which then it looks like you should be just fine
well still guessing on exactly what amp your running but if your putting out 1200w max power at one ohm. then i would just be careful with gain control and volume cuase you probably have enough power to blow them
i don't know about you but it might actually sound better if you run it to 2 ohms, being less ohms tend to not have as good of sound quality and 700w is plenty of power to rock them subs
I do not see a problem with an addition of up to a 600 RMS Class D mono amplifier with 4 ga OFC wiring supply kit and be fine. It would be...
10
886
$500 is not unreasonable, but just know about alternator shopping: There are two numbers that matter: The amp output at or near idle (what's it...
889
Are you saying that I should replace the jack on the headunit with a wire instead? Is that fairly simple? I'd imagine you would just need to make...
Specs https://www.skaraudio.com/products/vxf-15-inch-car-subwoofer
misterio
misterio
texas
Diplexers
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
