Can I run this setup at 1ohm?
You cant wire each sub @ 1 ohm. YOu can wire each for 8, or 2 ohms,or you can wire both subs together for 1 , or 4 ohms. Now if you had dual 2 ohm subs, then you could wire each sub @ 1 ohm.
I have 2 amps...would that allow me to run each sub at 1, 2, or 4? Sorry for the stupid questions, still fairly new at this.
look at the wiring diagrams under the wiring help section. it will tell you different ways the subs can be hooked up to.
like everyone said 1 dual 2 ohm sub can be wired to 4 or 1 ohm
1 4 ohm sub can be wired to 8 or 2 ohm
and
2 4 ohm subs can be wired to 1 ohm or 4 ohm
2 2 ohm subs can be wired to .5 ohm or 2 ohm
If you do not already have the speakers, just ge the 3002SPL's, they are the 2 ohm version //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
I have a pair sitting in my dining room, cant wait to get them in:D 5 cubes @ 32Hz and 75 inches of port area, 20.1 wired to half an ohm... I have heard good things about these Pioneers so I hope they live up to my expectations.
They will:up2somet:
NJTStang11
NJTStang11
Chicago, IL
Cbass
