Can I run active with this?
In the specs it says 2 way active crossover.
You can run active with it, but Lanzars only good stuff is their Opti subs and amps. I wouldnt run them for processing. And having a fixed 12db slope isnt going to give you the options you want when running active which is the reason you run active to begin with unless you can change the Q from the crossover or the HU.
Id look for a used Audiocontrol 2XS. They have module chips you put in them to change the slope I believe. Ge Off Me has one for sale.
If your on a super cheap budget, but dont want used Id look at this:
O2 O-XO3 Crossovers - Sound Processors at Onlinecarstereo.com
O2 has some great SQ from what Ive read. It also has the 12db slope though which will most likely be standard in a cheap crossover anyways.
Alpine W505/H701 combo or there are a few Japanese models available that do it. I know another is an Alpine xxxxJ or something and another is an Eclipse 55305CMT or something like that. Other than that no. There are a bunch that have time alignment though. If you run passives then you wont need active capable unless your planning for the future.
So if your head unit is active capable you don't need external crossovers? Sorry to thread jack but I'm just curious if an "active" capable HU is all that is needed?
Active capable HU. Amp with crossovers that can be set to full. 4 channel amp for a 2 way front stage, 6 channels amp for a 3 way front stage. Other than that yes an active capable HU with all the crossover and slopes is all you need.
Magnus
U mad brah?
Magnus
Midwest
Imtjnotu
