Had my system installed and the gain for the fronts is more than the back i guess its because its the back however can i put the rears up the same as the front also my subs gain is really low if i increase it what will happen.
why would the rears not be able to handle the smae power as the fronts,you can ,but most likely you'll send a clipping signal to the rears if you do .you can turn the fronts down.and as far as the sub amp ,you can set the gains with a dmm just to be safe.but it may already be set where it needs to be.
